It's just a power and a ground. Are you running it inline with an in-tank pump? Either way, this should be fed with a Relay directly off the battery to get full voltage with minimum 10ga wire. www.vfaq.com has a good picture write up on how to do a pump re-wire, follow that, but run the wires to this pump instead of or in addition to the factory one.
