how many cause of oil out at rod oil level
Kitti
Active member
Bangkok
now my engine have oil out at rod oil level then wot.
how many cause to be that?
i set boost around 22 psi.
i look forward to hear any advise. /ubbthreads/images/graemlins/worthy.gif
Barnes
Richland, WA
Sometimes the dip stick (oil level rod) gets old and loose and will come open under WOT. Get a new dipstick, or a 2g DSM dipstick if this is the case. Or just wire it down somehow.
Also, your PCV valve could be bad causing high crank case pressure. I would check this.
Or last, but least likely in my opinion; you have bad piston rings and you are getting a LOT of blow-by.
Kitti
Active member
Bangkok
tks for your advise. and i wish am shouldn't last case that mean a lot money /ubbthreads/images/graemlins/jawdrop.gif
the PCV if clean by solvent still back good? if not i will buy new both of dipstick and PCV.
and will try to check combustion again. tks friend. /ubbthreads/images/graemlins/worthy.gif
Barnes
Richland, WA
Yes, you can clean the PVC with solvent if it is stuck. If it is clean, you should be able to shake the PCV and hear it rattle.
mitsuturbo
Near Seattle, Washington
A short piece of rubber hose clamped onto the dipstick tube, and extending up past the end of it a bit is a good way to hold the dipstick in as well. This much blowby should be cause for concern, however. You may want to look into setting up a better breather configuration, as the setup our cars came with wasn't meant to handle the kind of things we do with our cars.
AWDPower
Vacaville, CA
I believe the saying goes that a good engine can blow out a bad dipstick, and a bad engine can blow out a good dip stick.
Kitti
Active member
Bangkok
past 10km ago i had check the combustion of my engine. the result is fine.(157-144-163-160)
if talk about breathe tube. the past have many oil out from breathe tube in front of turbo so i decide put a small fuel filler to into that tube. it better.
but now it out from rodstick.
the over setting boost(22psi) is reason, cause the oil it out then WOT? i use manual value to set my boost.
Kitti
Active member
Bangkok
/ubbthreads/images/graemlins/ooo.gif buy all these engine for this dipstick /ubbthreads/images/graemlins/rofl.gif
tks friend i will try to make it. i think it no to difficult.
