double syncro 1st gear?
Myles
Skokie, IL
Quicker cleaner shift to second and hi-rev down shifts for auto-x or road racing.
/ubbthreads/images/graemlins/dunno.gif
Double-cone synchro for 1st gear is no way affiliated with cleaner shifting to second :). IMHO only for rall / x-cross use. Don't waste your money on that upgrade, if your car is DD.
belize1334
Bozeman, MT
The synchro helps when you're shifting INTO a gear. If you autocross then a double synchro 1st and 2nd gear (and possible 3rd though it's used more rarely) will improve the shift feel. For drag racing the 1st gear synchro is useless but 2nd, 3rd, (and possible 4th and 5th if you're really going all out) will help with faster harder shifts. For a DD it's not really necessary unless you have the money to burn and just want a really smooth (but still clunky compared to a honda) transmission.
dsmtalontsi95
Glenville, PA
The build is for my weekend/track car. The guy building the trany said he would throw it in for $75. What would you guys do?
jepherz
KC, Missouri
I'd make sure I had 2nd and 3rd done first. What kind of "track" car? The chances of needing to downshift to 2nd in autocross are kinda low, but it's non-existent at a road course.
4thStroke
Vancouver, WA
Jack's recommends that you double up 1st if you plan on doubling anything more than 2nd. Then 3rd, then 4th.
Im doubling 2nd, 3rd, and 4th, myself. I like NLTS /ubbthreads/images/graemlins/smile.gif
In regards to shift quality, has anything added a counterweight to the assembly at the tranny? My Mazdaspeed3 had a weight and when removed, the shifting was light and notchy. It has a similar (very similar) affect to adding a heavily weighted shift knob.
