difference between afr and wideband
steve
NJ
You're going to have to try harder than that, dude. WTF are you asking?
Specter
Karachi, Pakistan
I think he is trying to ask if a wide band gives accurate numeric value, as the cheap afr gauges are normally not accurate and many only show rich/lean.
slugsgomoo
Tacoma, WA
Even though the question is... /ubbthreads/images/graemlins/uhh.gif might as well answer it properly. /ubbthreads/images/graemlins/wink.gif
Narrowband AF gauge = useless
Wideband AF meter = useful
boostedinaz
Scottsdale, AZ
Quoting Specter:
That's what I got from it as well.
To bad he isn't going to put time into writing something in a coherent manner because I don't have time to answer.
yeti
san diego california
Sorry the reason it sounds special-face is cause I don't know the right names for everything
What I was trying to ask was what's the difference
But from what I'm hearing
Its the same thing?
I really don't know sorry for confusing
steve
NJ
What leads you to think they are the same thing??? Look at slugs post:
Quoting slugsgomoo:
A narrowband blinky gauge will not be any use for tuning or troubleshooting the car. It will give a completely vague "rich" or "lean" reading based on the stock O2 sensor. The stock O2 sensor is not intended to read the AF with great precision.
A wideband is intended to read your AF with great precision, and therefore it will give you meaningful information with which to tune.
mountaineerjeff
west virginia
the confusion is because he doesnt know exactly what they are called.
they are both called AFR gauges.
one operates on a narrowband, and only gives you rich-lean 'guesses'
the other is wideband, and gives an actual AFR number to the 10th such as '11.5'
belize1334
Bozeman, MT
I think the question is more basic than that.
AFR = Air Fuel Ratio... It's a measure of how rich/lean your mixture is.
Wideband = Type of measurement device which reports the VALUE of the AFR over a broad range of values (from say 8.0:1 to 18.0:1)
Narrowband = Type of measurement device which reports the VALUE of the AFR over a narrow range of values (from say 14.0:1 to 15.4:1)
Most cars have a narrow band which helps them center the AFR on the ideal cruising value (stoich = 14.7 for gasoline). You can install a wideband if you want to have accurate readings under more extreme circmstances (typical AFR for BOOST is 10:0 to 12:0). A blinky-blinky narrowband AFR gauge is an attempt to get more info from a narrowband then is actually available. They're useless except as paperweights and they're lousy for that.
yeti
Thank you for the explaining
And sorry for the confusion
So a narrow band is not worth the sweat installing
Cause I got 1
And I thought they were the same because arnt they both AFR gauges
Just one is useless
