Clutch Master Cylinder repair
Diego
Bought a repair kit for my clutch master cylinder from RockAuto..... anyways what am I looking at getting into. Any advice on what to look for or anything I need to adjust after replacing?
Any tips are helpful
A tip yes.
Take the master cylinder to a very clean place to re build it, wash your hands and make sure NO forign debris get in there, no dust, no hairs etc, Kind of like brain surgery lol. This is what I was tought. Also check the master cylinder bore very closely for marks or imperfections.
Why not do the Slave cylinder at the same time?
Diego
Replaced that last month just trying to track down Wtf is wrong with my clutch being mushy...... this way if this doesn't fix my peddle feel then I will have to investigate the internals, hell my clutch and tranny doesn't even have 100miles on it since new.....
Are you having any trouble changing gear? does the car shudder when it's at idle clutch in, in gear? just had a problem with a toyota corolla with these things, was hard to shift so I double clutched it whitch made it even harder to shift. Was a master cylinder.
