1865 track day and DD
coyotes
Seattle, WA
So obviously my only hope of keeping up is to stay on the twisty tracks, or just hope you spin off /ubbthreads/images/graemlins/grin.gif
That is... Sizable. Nice work
turbohf
Lake Stevens, WA
wow. lookin good.
EHmotorsports
Beaverton
Thanks guys. And I think it would be a good fight at the ridge. Couple good twistes and a long straight.
turbohf
Lake Stevens, WA
so looking at this on my PC and not my phone. i love how the wastegate is going to support it self. like its aimed down, so the recerc dump is bracing it.
also love the audi wastegate, havent seen anyone use one in a LONG ass time.
i should probably read back threw cuz i cant remember now, but what are the specs on the motor and holset?
EHmotorsports
Beaverton
Yeah I may tack a small brace from flange to flange but I thought the expansion difference may make more stress on the tubing and promote cracking. But I may also run a brace from the WG to the manifold for vibration so it's still in the works.
It's an 8 blade HX35 with the BEP bolt on housing. The engine is a 6 bolt with 2g dsm pistons. Running ARP mains,rods and head studs. Stock cams for now but that will eventually change. EVO 8 exhaust valves,springs and retainers.
EHmotorsports
Beaverton
Heat wraped and ready to go. Waiting on the oil feed fittings and a resonator.
EHmotorsports
Beaverton
Thanks!
If I had the seats I would.
1dvsdsm
Arlington, Tx
I got a near new set of evo 8 fronts and rears for sale in texas if you're interested /ubbthreads/images/graemlins/grin.gif
EHmotorsports
Beaverton
I picked up a 3000gt vr4 brake setup using slotted and dimpled cobra 13" rotors.
The calipers needed some TLC so I decided to start cleaning and finishing them.
Tig welded the small dimples and started smoothing it all out.
EHmotorsports
Beaverton
A little paint and they cleaned up nicely.
Found some decals online and thought they fit well.
G
zompton
Looks nice, what was the welding for?
Are those 1g or 2g calipers?
Are the cobra rotors bigger than the 2g 3kgtvr4 rotors?
Where did you get those brackets?
EHmotorsports
Beaverton
The welding was to fill in small casting divets so I can smooth everything out.
The brakes are 1g 3kgt calipers. I am not fully sure the differences from the vr4 rotor to cobra rotors.
RTM racing sells the brake kits but I traded parts for this kit.
EHmotorsports
Beaverton
I have had the shield on for a while now. So far so good.
EHmotorsports
Beaverton
Finally building my transmission. DSM 1st, double synchro 2nd, HD 3rd and 4th, 4 spider center diff and Torrington bearing upgrade for the center diff as well.
EHmotorsports
Beaverton
Making seat brackets for the evo 8 SSL seats.
