What spools faster?? small 16g or Evo 3 16g
I'm not a newbie but this seems like a newbie question. i know that the internals on a Evo are lighter...Thats why i ask...
I never logged and recorded the difference but I can tell you it's negligible. The power difference is very noticeable though, so I'd go Evo 3 16g all day long.
Quoting RvlutionMtrsport:
never had a small 16g so i wouldnt know. I just know that i can make a soild 20psi at 3k and soild 25 at 3300 all the way to redline.
I just replcaed my small 16g with an evo 3 and I can't tell a difference in spool up. The evo 3 definately pulls harder though.
ktmrider
Tempe, AZ
^^ +1, for the setup I am running ( 2.5" TB, non-RS FMIC, switch to FP Race mani at same time ) the E3 spools 500rpm sooner and has no boost dropoff at higher RPM's compared to the S16g. This was with both at 17psi.
Armitage
Herndon, VA
What am I doing wrong? I only see 10 psi by 3000rpm on my Evo3!
Maybe the gianormous intercooler is working against me here? Turbo is new, motor is healthy/rebuilt recently.
mistaVR4
Boulder, CO
Sounds like you've got a massive boost leak somewhere bro. Have you tried searching for leaks? Couplers, TB gasket, etc..?
Armitage
Herndon, VA
Quoting mistaVR4:
Pressure tested the whole system to 20 psi. No leaks except the usual little one at the throttlebody shaft o-rings.
Rausch
Cleveland, OH
^ Car running rich or something maybe? Timing good?
ktmrider
Tempe, AZ
Quoting Armitage:
Possibly, I don't recognize the IC brand listed in your link. Any idea on the pressure drop?
Bar and plate designs are usually better on pressure drop, ie less than tube/fin, but have lower efficiency.
Also the size of your IC piping can impact things, I am still running stock diameter ( 1 7/8" or 2" ).
The small 16g does spool quicker. I currently have a small 16g on my talon, a big 16g on my Tsi, and i had a evo3 16g on my GSX. The differences in spool times are very very small. A big 16g spools just about as quick as an evo3 16g, but a small 16g spools a little faster. Overall though, like it was already said, the evo3 16g hits and pulls a lot harder. Its much more worth it
464/2K
Denver,Co
Switch to a smaller core, there was a link floating around about ic's affecting spool time some time ago. Iirc top to bottom flow was the best for spool time.
Armitage
Herndon, VA
Quoting VRausch4:
Probably running a little rich. I've tuned the partial throttle curves to get the fuel trims as close to 100 as possible. I haven't tuned for WOT yet since replacing the motor/turbo, but have all of the compensations in Jeff's chip for my setup.
Quoting ktmrider:
It's the I/C that was made by AWDNOT2 and later sold as a package a while back with the Dave Brode pipes. I'm using custom hot side pipes (2") and have fitted ETS cold side pipes (2.5") on there now.
