Galant vr-4 sitting for a while
NYC, NY
I have owned this Galant VR-4 for a least ten years.. Has been sitting at least six years and need help getting it going or getting rid of it.. No start / No power steering / No rear steer / No Brakes
gvr4ever
central Indiana
Where to start...
All fluids are crap. Might as well drain the gas tank. Timing belt should probably be done, unless maybe it was done right before parking it.
Before another start attempt, I'd make sure it has fresh gas and oil. I'd pour a little oil down the spark plug wells, wait 30min, take out the MPI fuse and crank over. The piston rings are probably dry and you might not have enough compression. Might need new wires and plugs. Things just wear out and dry rot years of sitting.
You got a lot of work. The good news is, the engine is very stout and likely still usable.
If you get it up and running, the brakes are probably frozen, tires trashed, break fluid gross, coolant bad.
NYC, NY
Thx for the info... I know these cars can be money pits unfortunately... But it was my dream car... I had a Mitsubishi mechanic but he lost his shop after some things ... Do you know of any mechanics in NYC?
gvr4ever
central Indiana
They aren't really money pits, they just don't allow neglect. Compared to a German car, they aren't really that bad, but they do require attention.
gvr4ever
central Indiana
Another part that might require attention is the crank pulley. It's not overly expensive, but look for dry rotting.
kdott96
Valley Stream, NY
Quoting gforce1661:
What borough are you in?
gvrfour1531
New member
Denver, Colorado
I just recently started a full over haul on mine after it sitting in a garage for 10 years.
Dream car for me as well so I'm stoked for it to be brought back to life.
God luck with the build.
NYC, NY
I'm wondering what is an amount that I shouldn't go over for repairs.or should I just by another car?
gvr4ever
central Indiana
Quoting gforce1661:
The ammount probably comes down to personal finances and how long you plan on keeping it. Any used AWD turbo car is going to require maintenance and upkeep the entire time to keep it running and performing very well.
I'd try and getting it running, up to temp and do a compression test. See if you have a healthy engine and than decide what needs to be done.
If it won't start, the fuel could be bad or the injectors could be clogged.
