Those with ETS intercooler kit
faqinshiet
Charlottesville, Va
Hey everyone,
I was going to install my ETS kit this week and was wondering what are you using for the front throttle body elbow bolts? Do I need to find two of the rear bolts and use those? Thanks.
strokin4dr
Savannah, GA
Yep, I used the same bolts as the rear.
faqinshiet
Charlottesville, Va
Another question regarding the kit is did you have to cut any of the metal at the passenger side at the intake side of the intercooler. The piping is not connect with the intercooler. Thanks
ghostinthevr4
Fresno, Califonia
The only thing I remember cutting was the front bumper support on the passenger side I did not have to cut anything.
Try putting everything on and installing the couplers loose if you put one on to tight you won't be able to put the other pipes in position.
The kit says you can retain your fog lights but I found it hard to do so I removed mine, that could be giving you a difficult time too.
ronkonkoma, ny
I trimmed the sheetmetal in front of the passenger wheel. I figured I was better off doing it when I was installing everything than finding out later the ic pipe was making noise and trying to cut it and paint it with the bumper on at a later date.
