No crank v. stumped
The car just randomly shut off. Timing belt is fine. No physical damage to spark plugs. Car rolls fine with clutch in, grinds to a halt after releasing the clutch. I didn't intentionally try it, just found out pretty quick after the car turned off.
Oil level is fine. Car tries to crank but does not turn over at all. Poopy
14u2nV
Agency/St. Joe, MO
Got juice? Dead alt and battery may be culprit. Cas still connected?
1990ggsxnj
Blackwood, NJ
Have you had your caps replaced?
Battery has good amount of juice. Caps have been done.
It happened while driving.
I haven't tried it since parking. I can try it next chance I get. Right when it happened I pressed the clutch in, tried letting it out and it didn't seem to want to start. I'll try though.
14u2nV
Agency/St. Joe, MO
You say it tries to crank, but won't turn over at all?? Do you mean it turns over, just won't fire, or will it not even turn over?
iLLeffeKt vr-4
NYC
Is it getting spark/fuel?
I've just started trouble shooting tonight. I don't have a DMM anymore to check spark/fuel /ubbthreads/images/graemlins/frown.gif
It does not turn over at all, but sounds as if it tries but the motor wont turn.
14u2nV
Agency/St. Joe, MO
Jumped time, bent valves? What do you mean it sounds like it trys, but won't? Starter clicks and spins, but engine won't move? Try doing what Wop said.
I'll try the socket idea. The starter clicks but won't/can't spin the motor over.
Also, I think I'm developing lifter tick. Doesn't happen at idle, just at light/moderate throttle reguardless of the RPM. Sounds like lifter tick to me, just wanted to run it by you.
^^^^This is what I described to Jon(toybreaker), he said it didn't sound like lifter tick to him.
rgeier11
Chicago Suburbs, IL
Obvious. The pistons are hitting the valves. Take apart the timing cover to see what went wrong.
i think you have had some timing issues. Pull the valve cover and look to see if any of the rockers are out of place. that will tell you if you have bent valves, or you can take off the timing cover also.
Yay!!! Guess it's not the worst that could happen. The car was nice and waited until I had a job to break.
Jon, did you PM me? I can't read anything, the proxy I'm on at work is rather touchy.
