Galant VR-4 Forums » Galant VR-4 » Technical Discussions » GVR4 Clutch Pedal Rebuild Kit no longer available at JNZ tuning
4dr_vr4
Galant VR-4 org Post #: 1229000 posted 06/09/16 04:59 PM     Remind Me!  Send Private Message   Edit Post
What is the next person going to do when their stock unwelded clutch pedal has play?
Are there any other sources?
Posts: 79 | From: NC | Member Since: 05/18/13 | IP: (73.251.121.143) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1229022 posted 06/10/16 09:12 AM     Remind Me!  Send Private Message   Edit Post
I thought anyone could remove their stock one and have it welded?
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1662 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (69.11.233.34) | Report this post to a Moderator
4dr_vr4
Galant VR-4 org Post #: 1229027 posted 06/10/16 10:32 AM     Remind Me!  Send Private Message   Edit Post
Maybe, but if the parts were worn, couldn't it be welded in the wrong position e.g. the position where there was play. I don't think it takes much play in the components to run into issues so you'd have to be spot on when welding no?
Edited by 4dr_vr4 (06/10/16 10:34 AM)
Posts: 79 | From: NC | Member Since: 05/18/13 | IP: (166.123.216.45) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1229028 posted 06/10/16 10:59 AM     Remind Me!  Send Private Message   Edit Post
I think this is how its done.. click
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
4dr_vr4
Galant VR-4 org Post #: 1229031 posted 06/10/16 11:34 AM     Remind Me!  Send Private Message   Edit Post
Huh, I have seen that a thousand times but never really read it. Seems to me that you don't need to worry about worn parts if you follow that procedure.
Edited by 4dr_vr4 (06/10/16 04:52 PM)
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1229033 posted 06/10/16 01:15 PM     Remind Me!  Send Private Message   Edit Post
Yeah he replaced the plastic bushing with a metal/brass bushing and just threw a bolt and nuts on it. I have to this to mine, Don't know if ill weld it or do this.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
donniekak
Member ++
Galant VR-4 org Post #: 1229066 posted 06/11/16 08:20 AM     Remind Me!  Send Private Message   Edit Post
I had a machine shop make me brass bushings for $20, and welded the end. The stock rebuild kits just fail again snyway.
Posts: 748 | From: surprise az | Member Since: 01/01/09 | IP: (2601:548:c101:23) | Report this post to a Moderator
DSSA
Old-Head
Galant VR-4 org Post #: 1229616 posted 06/23/16 06:55 PM     Remind Me!  Send Private Message   Edit Post
Just a note on this--
There are some other manufacturers out there making the bushings out of Brass as well, and typically they're close in price to our bushings.
We make (and have always made) our bushings out of Bronze, not brass.
It's twice the material cost of brass, and typically a little more expensive to machine, but when you're welding these pedal assemblies together, they're not easily taken apart to replace bushings without starting again from square one. That's why we spend the extra money (almost double the material costs) on the bronze.
The brass may work fine in most instances, but since it's a somewhat "permanent" setup once you're done, we felt the material costs were justified.
We discontinued making the bushing for the opposite end of the clutch pedal (the pedal side which you're not welding), as out of the 200+ pedal assemblies that we've welded over the years, I've seen only one or two bushings on that end (and for the brake pedal) that were worn to the point of REALLY needing to be replaced--it simply wasn't worth the costs to sell those to people.
Edited by DSSA (06/23/16 06:59 PM)
Posts: 554 | From: PA | Member Since: 04/16/02 | IP: (108.52.56.196) | Report this post to a Moderator
gaylantvr4
Joe
Galant VR-4 org Post #: 1229828 posted 06/29/16 11:21 AM     Remind Me!  Send Private Message   Edit Post
If the splines are worn out and their is play welding it will fail down the line. I have tried replacing bushings and welding and the weld cracks within a year.
998/1000
Posts: 850 | From: Omaha ,NE | Member Since: 10/03/04 | IP: (65.103.170.145) | Report this post to a Moderator
Generated in 0.05 seconds in which 0.036 seconds were spent on a total of 14 queries. Turbo powered.
