89Mirageman
Just picked up a 94 Mighty Max 2.4L, auto trans a few days ago. 194k on the odometer but the compression still reads 180 on all four cylinders. It has started missing under acceleration. If you gradually give it gas it will rev up nicely, however if you hit the gas very quickly it will bog and cut out. The ECU looks mint but I just replaced the caps anyway. Plug wires are new along with NGK plugs gapped to the correct specs. I also swapped in another TPS and coil, same problem. Any other ideas guys? I know its not GVR4 but the basics are the same. Give me some more options to try. Thanks in advance!
