WTB: rear pumpkin prefer local Portland OR
dime2nr
Portland OR
Looking for a rear diff housing with 5sp gears differential not important or needed. Anyone got a cheap 1g non lsd rear end no axles needed that I can get for cheap?
Do you need one with the 4ws gear hole or without?
transparentdsm
Cherry Hill, NJ
ill can give you the pumpkin, rear diff with 4ws ring and axles for 100$ and pay for my gas money to meet you wherever you would like.
dime2nr
Portland OR
Without 4ws thats long gone. Basicly this is so I can put a clutch type lsd in as a quick and easy as a remove and replace job same day. unless there is a shim kit I can buy before hand so I dont have to run the risk of having to wait to determine what/if i need shims and then order them. my general luck says I will need to as or subtract shims
GSXftw
medford, OR
I have the stock diff out of 1722. If you dont have the 4ws rod ends hooked up it should be fine yes?
