WTB: 92-94 5 lug swap w/ abs rings (43F/43R)
Launch
Texas
Hello guys (and gals)
395/1000 is getting a new lease on life, with a updated trans and some new lighter shoes.
Need 5-Lug swap hubs, with their abs rings. 92-94 DSM with the 1:1 ratio 43F/43R)
Need to be in good shape, PayPal/bank ready
Thanks guys, can't wait to be back on the road
-Launch
citymunky
Chesapeake, VA
I'll check the swap kit in the garage tomorrow, I believe it had ABS rings on it.
citymunky
Chesapeake, VA
I checked today, and they were non ABS. Sorry man.
Launch
Texas
At this point, I'd take non abs hubs. What do you want for them bud?
Quoting Launch:
You can use 92 VR4 rings and adapt them to the 5 lug hubs. Actually I believe the 1g parts are 47/47, and the Galant 43/43 (92 only). The important parts is the 1:1 ratio.
So, you can pull the rear rings off the 4 lug stubs and reuse them on the 5 lug stubs, and then adapt your VR4 front rings to the 5 lug front hubs. They actually mount nicer (from the rear , no bolt heads on the rotor mount face) than the 1g versions.
KiNgMaRtY
Corona, CA
Must the doner 5 lug hubs be abs specific to be used with the 4lug rings or does it not matter if the 5lug hubs were never abs specific to begin with?
The ring designs between 5 and 4 lug systems (1g vs, Galants) are different and so is the mounting. You would have to drill and tap to mount the rings to non-ABS hubs.
Launch
Texas
ICEMAN for the win! thanks for the info. Any 5 lug hubs avail or am i going junkyarding?
