volume air flow circuit malfunction
LordAthey
Council Bluffs, Iowa
Hey guys I'm getting this error on dsmlink and not quite sure what to make of it. I had a 3g maf plug in so I switched it out for two different working 1g's and still getting the same thing even after I reset the codes. I removed the safc that was in place but its still doing the same thing. Mods are 650 injectors, big 16g turbo and a front motor intercooler 2.5 inch pipping with a 1g mas as of now. I've tried resetting the throttle position and the car starts to buck after 3k. I think that somewhere the wiring may be bad, but I'm not sure what to make of it since the car ran fine till I switched to the 3g maf with the adapter. Any advice would be great!
Thanks,
Scott
toybreaker
iconoclast
How's the board in your ecu?
... might be worth a look if you've swapped multiple airflow meters /ubbthreads/images/graemlins/dunno.gif
LordAthey
I knew I forgot to post something /ubbthreads/images/graemlins/banghead.gif. It was rebuilt by dsmlink about 4 months ago and haven't had any issues with it, but I will pull it out this weekend to make sure that everything looks fine.
toybreaker
iconoclast
... there's a ground trace on the board that causes some problems *similiar* to what you are describing
Everything else read/log correctly?
Tommyd
Fishkill, NY
I'm having the same issue. Its logging values but still throwing a code and not idling/stumbling past 3k.
