derek963
New member
So here is one more no start thread, just in case you guys needed another. bought #963 in pieces, put her back together, got her running, found out it needed a headgasket. Tore her down, and she hasnt been running since. Obviously everything is back together. Mpi relay-replaced. Have spark (cas is good?). Walbro 255 is pumping. BUT, the injectors wont fire. Put noid lights on it and im not getting anything.
Now im going to list everything i know to be a problem, if it effects anything im not thinking of, feel free to call me a dumbass and tell me to fix it.
Wires running to the coolant temp sensors are dog doodoo. Some of them arent connected to the connectors. Those obviously need to be cut and spliced before she hits the road but i have bigger problems as you can tell. Now i know our cars are picky about those but i am to understand that they will start without all that.
I know i did the same thing to an alternator wire when i was tearing the head off.
Missing the little sensor by the throttle cable (not the tps)
Some vacuum leaks here and there.
she DID start for a brief second with starting fluid sprayed into the cylinders.
Checked all the fuses, done everything i can think of. Changed eprom chips.Injector resisistor is coming this week so well see what happens there.
If any of you gurus have any ideas i would love to hear them. /ubbthreads/images/graemlins/banghead.gif
