tires the further educating of a newbie. back for more suggestions?
kooter
carpentersville, IL
keeping my stock 15 inch rims
which is my best tire size to go with?
I am no speed racer, but who know's maybe someday I will learn to drive.
so should I go 195/60/15
or 205/55/15
I just don't know.
SouthCaliVR4
North county San Diego
when I was still on 15's I was running 205/60/15's go with a good tire & a speed rating of "h" or higher to help with the handling, stiffer sidewalls on higher speed rated tires & typically a softer compound, both will help.
kooter
carpentersville, IL
YEP
thats is right I said 195/16/15
what I mean was 195/60/15 of coarse
2of9
IGH, MN
I've had 205/55/15s on once. Specifically the Falken Ziex 512s. Tires were awesome in the summer. Because of bad alignment, the tires only lasted about 25,000. Supposively these tires are "all season". Tires were decent in winter, probably about 2.5/5 in winter. I'm currently on the 195/60/15 512s H-Rated. Tires burn pretty darn fast when you don't have your car done for an alignment. But, being on an H Rated tire, it went out pretty quickly and I'm pretty much due for new tires once spring comes in. I believe our cars are supposed to have T-Rated tires but please correct me if I'm wrong.
There are many factors that play in if you want a longer lasting tire; speed, tire pressure, weight, etc etc etc. But, if I had a choice of all season tires, it'd be investing into the Michelins for the high end.
For my personal usage
Summer = BFG G-force
Winter = All seasons because GVR4 in winter is just pure pwnage
EDIT:
Personally, stick with the 195-60-15 tires. To me, the car feels where it should be. With the 205-55-15 tires, the sidewalls are a bit smaller compared to the 60 series so if you hit a small pot hole, you'll feel a slightly harsher bump compared with the 60 series, but this is me, it will vary.
Definitely 205-50, or 205-55 FTW! 1947 has 205-50 and it sits perfect and rides/handles nice.
Olson
Moreno Valley CA
If you get a 60 series tire its going to start to look like a monster truck with the big side wall. stick with a 205/50-55/15 tire
kooter
carpentersville, IL
so I am thinking the orginal 195-60-15 will do for now. but now onto what brand , always so many choices
2of9
IGH, MN
links work but we can't see what your options are.
kooter
carpentersville, IL
yea it did not work out as I planned
Potenza RE960AS Pole Position 195-60-15
Pilot Exalto A/S 195-60-15
2of9
IGH, MN
You got Fuzions? I don't mind the stock size. Looks much more like an Accord /ubbthreads/images/graemlins/devil.gif
kooter
carpentersville, IL
that is what came on the car when I bought it.
they are in need of replacement.
kooter
carpentersville, IL
well ordered them today
195-60-15 bridgestone potenza's re960as
misterfixit
Midlands, UK
Over here my tyre of choice is a Pirelli P6000, I have the in "v" rated. Not the quietest, but the water dispersal is ace and the difference between wet and dry is negligable.
Had Falkens ziex 512s, goodyear eagle gt, yokohama a359 on my sunny and they were ace in the dry, but the slightest sniff of moisture and you had to totally alter the way you weighted the car up. Scary sh*t in the near constant drizzle we get here.
For tyre sizes width is purely a preference thing. I like strong stock size tyres.
The side wall height is the % of the width so 0.6 of 195 is 117mm sidewall. 0.5 of 205 is 102.5mm sidewall, 0.55 of 205 is 112.75mm sidewall so a small difference in rolling diameter of 8.5mm(2x4.25) from 195/60/15 to 205/55/15
Rich
