this is why my car isn't lowered
kitcho
canada
just went outside and snapped these. car is at stock height, street went from fine to several inches of water in minutes, water is almost in my exhaust.
kama1
q.c. philippines
This is how my vr4 got eternal rust
Working in the province,house beside a river that goes straight to the ocean
Everytime hi tide comes there no where to hide.salt water kills cars fast.
fuel
Toronto, ON, Canada
I would be moving it before it gets any higher! even at that height you run the risk of water entering the cabin, you just don't know if one of your floor pan bungs is missing until your interior is saturated.
kitcho
canada
so i checked my car before heading off to work this morning....
the floor mats and carpet on the left side (passenger side since its rhd) is soaked. Apart from drying out the carpet with a wet dry vac, what should i do? \
thanks
steve
NJ
Quoting kitcho:
Move.
jepherz
KC, Missouri
Quoting kitcho:
thanks
Pull the carpet out and wash it. Let the floorboards dry out. Check all electrical connections that may have gotten wet. Otherwise you may run into problems years down the road, that's why floods normally total cars out.
curtis
Clarksville TN
Pull the carpet You can get it out with out removing the center console but will have to cut the carpet in the middle. Then take it to a car wash and pressure wash. Dollar general sells some stuff called totally awesome for a dollar a bottle that works wonders. After that as was said check electrical stuff ecu plugs etc and then after letting the car dry put a dehumidifier in the car and let it run for a few days it will suck the moisture out of places you can't get to.
I cleaned up my wifes xterra a few years ago and pressure washed the seats after I got them out and did the door panels and some of the places under the carpet as well as the air vents. I let everything dry outside for a day then put it back together and put the dehumidifier in and pulled out probably 15 gallons or more over the next 2 days but when done smelled like a new car.
