Thicker head gasket
TylerAdamson
Iowa City, Iowa
I'm pretty sure that at one time you could get the HKS head gaskets in different thicknesses. Not sure if that's still the case though.
JNR
ca
Just remember that a thicker head gasket will lower your compression, if that's a concern...Don't know the formula off the top of my head, but sure it's out there /ubbthreads/images/graemlins/grin.gif
Kenny_Kline
Seekonk, MA
Quoting Garfield Wright:
What's your motor setup?
Head is at its survice limit, BC 272s, +1mm oversized valves, 1G pistons, 1G rods, 2G head. I have a 4layer MLS on and valves are just touching.
I actually found a Cometic .061 MLS head gasket. I think I am going to run that. Not sure yet. They also make a .07X. I have to measure the piston to valve clearnace and go from there. .054 isnt enough. I have little tiny dings on all my pistons (fresh marks) but valves are still good.
Cometic seems to be my best route.
Brianawd
Portland OR,
Clay the pistons so you can measure how much more clearance you need.
Or just find a new head that has never been machined. That way you know your good
Cometic should be a last resort which I think thats where you are now. Unless the block & head are PERFECTLY flat, it's going to push water. I was going to recommend the same as Brian but I'm sure you just dumped some money on that head. Member 630 is selling a really nice 2g head. I'd recommend you pick that up but find out some more specs on it so you don't have the same problem.
Kenny_Kline
Seekonk, MA
My head has alot of machine work in it. Over sized valves, seats cut to fit, bowls blended into seats, extensice exhaust port work, combustion chamber clean up, drilled head stud holes, bronze valve guides, new cam seals, BC 272 cams, revised lifters, BC springs/titanuim retainers, new valve seals...
I spent alot of time and money on this head. If I were to do it again, it would be cheaper to swap to a good 2G head core and re-do everything.
I talked to Cometic this morning. They said they have what I need all the way up to .150". I will probably need a .06X-.07X and will know for sure when I measure the piston to valve clearance. Cometic said they redisgned there gaskets. 5 Layer with viton rubber seals on both sides of gasket like the 4layer MLS from Mitsu.
I just had the head resurfaced pefrect finish 200 miles ago. I will check it out. The block I am going to have resurfaced. Going to try and run a Cometic 5 layer with a coating of copper spray. I may ditch the ARP head studs. Will will see what happens.
I'd stick with the arp's, that way you can reuse them when your checking your clearances. Also they will hold up way better. I'd call AMS and see what they recommend as far as gasket thickness. They should be able to give you a ballpark number.
Brianawd
Portland OR,
why would you put all the money into a head that can no longer be milled. Seems like a big waste of money /ubbthreads/images/graemlins/dunno.gif
bazeng
Melbourne, Australia
Tomei have the thickest from what I know.
1.8mm
HKS have the 1.6mm
Cometic have the 1.2mm (used to have the 1.6mm but for some reason I can't find them anymore)
