Temp gauge stopped working
Boos929
Active member
Mass
Temp gauge stopped working today what should I look for that would cause this problem ?
MellowVR4
Milwaukee, Wi
probably an old sensor, single terminal sensor on the thermostat housing.
Boos929
Active member
Mass
Is that the sensor that wired into the top of the thermostat ?
MellowVR4
Milwaukee, Wi
No, its just a one wire connector, not sure if its in the front or rear of the housing. lower portion of the housing.
Boos929
Active member
Mass
A small 1 wire black connector ? I have one not connected but can't figure out where it would go
MellowVR4
Milwaukee, Wi
i cant remember if its black ot not, i thought it was yellow /ubbthreads/images/graemlins/dunno.gif cant rmember tho.
MellowVR4
Milwaukee, Wi
im pretty sure it the sensor next to the coolant temp sensor which is a two pin sensor.
ktmrider
Tempe, AZ
Sensor #1 below:
desant78
Clarksboro, NJ
and to clarify, since your temp gauge stopped working, you are looking for sensor number 1 on the above.
I'd check if it's connected/if the wire broke. I had a few miles on my car before all those wires fell apart from vibration and being so old.
Good luck!
ktmrider
Tempe, AZ
^^ LOL I guess the first line, "Sensor #1" was not clear enough?!? /ubbthreads/images/graemlins/wink.gif
Boos929
Active member
Mass
thanks think i found the issue the sensor has a small black plug on it and other have of plug isnt connected tryed to get it back connected but got to damn cold out will try again tomorrow thanks again for the help
desant78
Clarksboro, NJ
Quoting ktmrider:
Ya never know! Those arrows could confuse a guy, ya know lol honest i didnt read the first line.....oops!
