sunroof drain tube locations
my sunroof pan isn't draining. before I stick my compressor nozzle in the drain tubes and blow it out, i'd like to know where exactly they come out. thanks
Dustin
ggsxkid
La vergne TN/Lake Zurich IL
if you pull off the sun visor and oh S*!# handle and pull down on the headliner you can see exactly where the rubber tube from the whole sunroof assembly goes to the a pillar
yes, I understand how to tear a bunch of stuff apart, but i'd rather not. hoping someone knew where they "exit" the car
misterfixit
Midlands, UK
rears go down inside the c pillar and then into the cheek between the rear chassis rail and the outer skin behind the rear wheel. sits in a grommet that exits the car towards the centre!
Rich
