Okayplayer
Okay, I just dropped the engine back into 1968 and I am having some serious issues. First the engine sounds like it's running pretty rough. The reason I pulled it was I had a spun bearing on the #4 rod bearing. I changed out all rod and main bearings and the crank. I replaced all the seals on the front case and tensioner etc. The engine is running rough and the timing belt seems pretty loose. I reckon that the timing is off a bit and that's the reason for the rough running.
I also changed the clutch slave cylinder. I bled the crap out of it but the pedal feels super sloppy and is not coming all the way back up so I will bleed it again.
Now a real concern in the midst of all this is starting the car. It chugs pretty hard 3 or 4 times to get going. I just got finished changing the old starter because it crapped out. I noticed there was some fresh metal shaved off the mating surface to the block
What could cause this? Is there something I'm doing wrong when I install it or is the flywheel some how sitting too close to the block? I'm at a loss and I am very ready to throw my hands in the air and find a new project. Please give me some insightful input
