Stainless Steel Hydraulic Clutch Line for a Galant Vr4. Where can get some?
alansupra94
Wayne,NJ
Honestly, you can pretty much use any goodwrench stainless steel brake line. I used a line off a kit for my dad's RX08. He totaled it and I found it lying around. Worked 100% and looks just like the line I replaced that was fubared by the previous owner.
SmoothCustomer
Lexington, KY
Well the 2g will go all the way from the master to the slave on a 1g, but if you get a 1g stainless line you will still use the factory hardline. When using the 2g you need to make sure you still get it nice and secure.
stealthtt24
Orlando, FL
OK I'm not sure if you guys have bought that 1g hard line, but it is way longer than the whole master to slave setup. You will replace the whole line, metal and rubber, plus much left over. I will post a picture but I purchased a 1g one from Extremepsi back in 09'.
stealthtt24
Orlando, FL
mistaVR4
Boulder, CO
Quoting citymunky:
Hard lines are better than any hose, I would stick with a 1g clutch line.
Agreed! If your hard lines from the master to the junction between the soft line and the slave Cyl are in nice shape the 8" SS line that connects from the hard line junction to the slave, the short line will work just the same..
