Shift linkage bearings
1990ggsxnj
Blackwood, NJ
OK, so a few people have done this mod. Use roller skate bearings in place of the bushings inside the shifter linkage eyelets. Does anyone know which ones these are, have sizing specs, cheap place to order, etc.?
Muskrat
Lexington, KY
Pull a bushing and measure the I.D. and O.D. of the bushing, then go to a skate store buy a bearing that's the same size.
Or you could just buy a shifter bushing kit.
JNZ makes delrin ones.
speed-source.net sells brass.
gmp
Denver,co
i just used some skateboard bearings there a good solid feel to the shifter. The only thing you really have to do to get them in is file the loop thing that holds the stock bushing in and then just get some "slip joint pliers" channel locks and press the bearing into the loop...
the bearings are a bit tight to get in but once in i feel like you wont ever have to replace them again.
hope that helps if you need any pic or some thing i can post some pics.
oh also if you go to any skateboard shop they usually have old ones kids left so you can get them for free or for like 2 buck or so just got ask thats the only real cost to you most the time...
GMP
