*** RESOLVED***Strange noise from below.***RESOLVED***
That's a good one. What kinda clutch do you have? Also does it change when you push in the clutch pedal?
Captn
ACT 2100, I was thinking something to do with the clutch. I will check to see if it stops when clutch is in.
I will do some investigation. Gotta have some better weather /ubbthreads/images/graemlins/frown.gif rainy and cold today and snow tomorrow I hear.
Also while checking on the clutch, hold the clutch in and put in gear and neutral. See if the noise changes between in gear and neutral. I had a trans mainshaft bearing go and it made a similar noise.
460GVR4
tacoma, wa
my flywheel came loose once since I didn't apply any thread lock. My flywheel moved hundredths of an inch on crank and made a horrible noise similar to a rod knock. Just an idea. GL
Captn
Yeah I will be sure to check that all.
I personally didn't install the clutch or flywheel.
Thanks for the help everyone, I just hope it's not my engine.... Spent a lot of money on it and the build isn't done yet, would suck if something happened to it.
Also its my only car!
Captn
So I had my wife push the clutch in while I listened...
It went away! Does this mean is the throw out bearing?
I have some loud belts though not sure which one it is...
Barnes
Richland, WA
My transmission did the same thing when the transmission's outer intermediate shaft bearings were going bad. /ubbthreads/images/graemlins/frown.gif
Thankfully it's a relatively easy thing to check.
Quoting Captn:
Throw out bearing or the mainshaft bearings are bad. Check your trans fluid. Mine did that for a while. Ended up being the mainshaft bearings. NON oem throwout bearings will fail and be noisy.
Captn
So if my throw-out bearing is fine it is most likely the main-shaft bearing?
How would I check/replace that if possible?
I'll check fluids too.
Barnes
Richland, WA
Checking the intermediate shaft is pretty easy. You simply pull the end cover off the transmission. You can then grab the 5th gear on the end of the intermediate shaft (between the input shaft 5th, and the vicous coupler) and see if it moves. This shaft should have no play. When mine was going bad, it moved probably 1/8th to 3/16th of an inch laterally. /ubbthreads/images/graemlins/ooo.gif
You can check the input shaft the same way to see if it is the culprit.
Does your shifter move when you get on the gas and let off? If it does then it's the trans. The two nuts on the end of the shafts under the rear cover tend to loosen up. Causes the bearing to fail. Which in one of my trannys caused the sandwich plate to get damaged by the gears.
Look it up under vfaq and drivetrain then shifter movement fix.
Barnes
Richland, WA
I'm 99% sure those nuts only hold the 5th gears on. The nuts on my 5th gears were tight when I discovered my failing intermediate shaft bearing. Since my input shaft bearings were not failing, and the nut was tight on the input shaft, I had no shifter movement.
CORRECTION: The nut on the input shaft holds 5th gear and the 5th/reverse hub slider. The 5th gear/reverse shift rail is consequently connected to the hub/slider. Thus if the input shaft nut is loose, you get movement.
Captn
I just drove it around the block its pouring rain here right now.
I meant the shifter has play not the shafts sorry for the confusion.
Your not checking for play in the shifter.
When you drive with your hand not on the shifter and put a load on it then let off, your watching to see if the shifter moves by itself. This tells you if the gears and shafts are moving, which tells you something is loose or there is excessive clearance in the shafts which can generate the noise your hearing.
