removing etacs
dime2nr
Portland OR
if i remove the controller and the related wiring will i loose the wipers,lights,blower motor,or tach?
i believe so. go try it and let us know. its just the ecu box above the clutch pedal
Spyke169
Greenfield, Wi
My etacs doesn't work right now, things that don't work: Adjustable speed on wipers (the second 2 will still work, it's the one you can adjust by turning the knob that won't work), power door locks, sunroof (if you have one), power seatbelts with the ignition off, radio, key reminder, factory alarm (if you have one), dome and door lights. there may be more I'm not remembering right now... but those are the ones I can think of
