For those of you that have used a 1g radiator to half way tuck under the upper support what method did you use to move back and remount the a/c condenssor? If you have some pics that would be greatly appreicated
I use the stock mounts at the bottoms for both, but I re-made brackets to lean the A/C condenser as far forward as it would fit, then the radiator the same way, leaving just a bit of air-gap between the two at the top. Sorry I don't have pics of them, but the top posts are about even with the back of the rad support.
