Quick Question
GVR47111K
80022, CO
Is a clutch master cylinder for our cars one of those parts that I wanna buy OE rather than paying twice (or even more than that)?
Any recommendations for a specific one?
Will this one suffice?
Thank you all,
992gnt
Edgewood, KY
I just picked a Dorman clutch master from Rock Auto for a bit less than that. I'm not a big fan of the "Duralast" pieces, but in reality how many manufacturers of these things are really out there?
transparentdsm
Cherry Hill, NJ
for that price go to rockauto use the promotion code we share on this site to save a bit and get the BECK/ARNLEY Part # 0728847
edit- ^ nice call.
Brunoboy
San Bruno,CA Home of SFO
I've done the autozone slave and master, never again. A local on tuners did the measurements of oem vs autozone and it was significant enough to cause problems.
desant78
Clarksboro, NJ
I forget what I ordered, probably what Transparentdsm is recommending. I can offer that there are good threads on this site about the exact master cylinder to use. It's old, but I followed the thread and ordered the master/slave cylinders, and they worked great!
A none-oem brand is recommended and proven in the thread along with a part number. Good luck!
GVR47111K
80022, CO
Thank you everyone for the responses.
Would it be worth it to just order a replacement kit from JNZ or is it better to just ditch the old one since it is 20 years old?
I'm trying to pinch pennies. /ubbthreads/images/graemlins/uhh.gif
desant78
Clarksboro, NJ
I LOVE my new ones, honestly best "mod" I did to my car for drive-ability. It wasn't too pricey either. Definately look up the parts to help with your decision!
992gnt
Edgewood, KY
I wouldn't waste my time rebuilding a part I can buy new for $35. YMMV
I say it depends on your set-up. A stock car will get by with aftermarket, but a car with a heavier clutch should stick to OEM. That's my opinion based on the amount of clutch disengage issues our cars can have when using beefy clutches.
Also replace the hydraulic line too while your in there. Also using a 92 spec slave cylinder will get you better pedal feel.
