Using Summit Racing parts you'd want:
Red/Blue Anodized:
-10 fitting, hose end, straight
SUM-220090 $8.95
-10 fitting, hose end, 45 degree
SUM-220086 $16.95
Black Anodized:
SUM-220090B $8.95
SUM-220086B $16.95
Nickle Plated:
SUM-221303 $8.95
SUM-221313 $14.95
Shortest hose I could find in -10 was 3ft (you only need about 6-8 inches, at least that what I keep telling myself
-10 Stainless Steel Braided Hose
SUM-230003 $19.95
2 ea. Extreme PSI Billet Aluminum Turbo Oil Drain Adapters
PSI-FLG-MIT 2 x $24.00
(I found a Russel's fitting for the T25, T28, TO3 turbos on Summit, but wasn't sure if that would be compatible with the Mitsubishi oil pan drain and turbo outlets)
Or you can just buy the kit from Extreme PSI or Slowboy for about $90-$100
Edit: Forgot Mitsu drain gaskets, $2.00 ea.
