Paint code....Belize Green
Just wondering if anyone happened to know it off hand....
If not i can obtain it from the dealer i presume right?Thanks, Dave
it should tell you the code on the door jam where it tells you the weight of the car ect...
Romanova
Cypress, TX
Good luck getting touch up paint from the dealer. My dealer had to order white touch up paint from Japan for me... said there was none in US. Took FOREVER.
GL...
the code off the green 92 we have is
"G31"
just go to your local paint supply store and have them mix a pint for you.
or you might try mitsubishiparts.cc
Robert
M&S
thats a bunch of BS. I got touchup paint for my car at autozone. it is the same white Mitsu has used for years so it is easy to get. Summit White is easy to get. belize green might be harder but try like PPG stores or something.
Thank you....Mine is a 92 also ....I am going to check around.I have a nasty rust hole on the hood so i got a new one from the previous owner along with the car as he planned on getting it done but didnt so now it is up to me to restore it.
