Oil pressure
Can someone tell me what the oil pressure is at idle and cruise from the oil filter housing. Thanks! I am running a ceramic ball bearing turbonetics turbo with no water lines and I need to know if the feed should be restricted or not.
steve
NJ
I see 10-15 at idle and I'd have to check cruise to tell you for sure. I'd throw a guess out about 50-60 psi. /ubbthreads/images/graemlins/dunno.gif
About 15 psi idle. Cruising between 2500 and 3000 RPMs I see about 60-65 psi. Freeway speeds it's around 70-75 psi. This is with a ported oil filter housing and no balance shafts when the engine is up to temp.
they arent bad I just fed the beast from the head now she aint grumpy no more
