AuSpecVr4
Hi
It's sad to build a fresh motor and spend all the time making sure everything is alright and works and be ruined by oil leaking after all your hard work. My oil feel for my turbo is leaking bad, under inspection, the top feed has been helicoiled, and when i removed the banjo, it pulled it out with it, if i go ahead and re do the helicoil is it safe? with the potential metal shavings? i've used new crush washers and bolts and still have this leak.
Cheers
Cheers
