So I can't remove the shorty filter with my 3" downpipe and 90 OFH. I'd like to get a relocation kit but I'm unsure on which housing will fit/work best. Info on this seems to elude my searches.
I've seen that. I've also read that those adapters leak quite often. Also would like for the adapter to have 90° ports to start with instead of using 90° fittings. Leaning towards this
I think most aftermarket universal kits you buy would work fine. I DEFINITELY wouldn't use any lines paired with standard barb fittings and worm gear hose clamps though. If I was going to use the kit in your link I'd throw those barb fittings in the trash, and use AN fittings with braided lines...or push-loc lines at the very least.
