My vr4 giving new owner issues
James
Port richey Florida
Well the guy made it 2 days I think before something broke /ubbthreads/images/graemlins/banghead.gif here's the video of the noise it's making and here's some notes...
Happens clutch in or out
Coming from trans area
Happens in or out of boost
James
Port richey Florida
He said if he was deaf he would never know something happened. It drives like normal... Just the noise. So I don't think it's the clutch.
I told him to check the driveshaft and the axles. I suggest possible TOB is shot an he said maybe wheel bearing shot.
LIV4PSI
O-H-I-O
Throw out bearing sounds more likely to me, than axles or the driveshaft
fuel
Toronto, ON, Canada
if that were the case then the center diff would send most power to the front and it would feel like it has a slipping clutch - this is assuming that the VCU isn't locked of course.
CutlassJim
Manchester, NH
Quoting mitsuturbo:
Sounds like stripped input splines in the transfer case. I've seen this a couple times myself.
Since it happens with the clutch in or out I am voting stripped splines on the clutch disk.
James
Port richey Florida
Sweet glad to see you got on here.
So the problem is still the same. Terrible noise from the video. Clutch in or clutch out. Only when the car is moving.
LIV4PSI
O-H-I-O
Take it back to the shop that said it was the wheel bearing. After making you waste money, the least they could do is diagnose it properly
donniekak
surprise az
Quoting SynHaven:
Hey guys, I am the new owner
Get the car on a lift, or 4 good jack stands, get it to make the noise, and start searching with a stethoscope.
SynHaven
New member
Orlando Fl
I could take it back to the shop, but honestly im just frustrated. No one including my self has any idea whats making this mystery noise. Tranny and clutch feel fine, and pressing in the clutch or shifting does nothing. stepping on the brakes does nothing. turning does nothing. and the rear diff has oil and its clean. we also didnt notice anything wrong with the rear axles while we were under the car. im just annoyed.
James
Port richey Florida
Turns out the TC has no fluid in it. How would this happen? How long can the TC go with no fluid (and not making any noise).
I replaced the fluids before my vacation about 6 months ago. I took the car on a 2000 mile trip. I've put about 4000 miles on the car since then. And I drove the car two hours to Syn with no weird noises or problems.
I have no weird leaks on my driveway that should TC leakage and he has none on his.
Anyone have any ideas? Adding fluid to the TC cured the problem though he says it's still make a weird noise... Probably due to it being driven dry.
fuel
Toronto, ON, Canada
I bet the front driveshaft yoke has sprung a leak from the frost plug inside. It should have been covered by a recall and the recall kit fitted is a new yoke with a completely sealed up end - ie no possibility of leaking through a frost plug. Either that or the TC output shaft seal is bad or you have a leak from the drain plug. Check for obvious oil leaks around the TC area. I would not continue to drive it any longer as you risk having the TC simply locking up which would make the car uncontrollable.
FlyingEagle
THE Ottawa
Quoting James:
If the noises are still coming from the transfer case as shown in the video, you 100% have some bearing damage. No bearing can be run dry for any length of time and survive. Best to pull the parts and inspect, or replace the TC. If the car did not exhibit these noises when you owned it, you didn't know about the issue, nor could you have. Not a super costly repair, just an unfortunate circumstance to come about in the timeline of the vehicles life.
