as iceman said, the metal brackets that mount to the block and trans, the trans side and timing side are the same, but the front bracket that bolts to the block is different. its stamped with a 344. as far as i know, the engine mounts that bolt to the body are the same, but i think there was a member that had the avid mounts and they had difficulty with one of them and had to use a stock with poly insert.
