for the Balance Shaft Eliminator
bigblock4g63 Well-known member Joined Feb 10, 2009 Messages 308 Location new jersey Jan 1, 2014 #1 for the Balance Shaft Eliminator
Struc Well-known member Joined Nov 24, 2008 Messages 764 Location Oconomowoc, WI Jan 1, 2014 #2 Are you talking about the plug for where the balance shaft used to be in the front? Or are you talking about the replacement spacer for the balance shaft gear on the crank?
EMX5636 Well-known member Joined Jun 28, 2008 Messages 1,631 Location Bucks County, PA Jan 1, 2014 #3 This is the number for the metal spacer behind the timing (TDC) plate on the crankshaft. MD128107 I think this is what you are referring too.
