Romanova
My feed line from the pump housing to the front of the car is pretty trashed to the point where it is unusable. I want to cut the feed line off flush with the housing and drill it out. Then I want to use a Walboro 255 with a short piece of fuel hose to a -6AN barb fitting, then a -6an seal against a 90 degree -6AN bulkhead fitting, then -6AN line to the fuel filter...
This is similar to the Bosch 044 install I have seen before... should work no problem right?
