belize1334
COP setup made with intrepid coils.
Wired with my own design which charges the first coil on each channel in reverse so that when they fire the two coils make a closed circuit. In theory this is better than the usual design and should give stronger, more consistent spark. In practice I can't tell the difference, it's at least as good as the more common wiring method.
To run you should get a roll of high-temp electrical tape to wrap the loom and seal it all up. Other than that, it's completely plug and play. I had it running in my galant for about a year with ZERO issues (aside from my own stupidity on one occasion). The car idles smooth and pulled 20psi on my 16g without a hint of breakup or hesitation.
