pot
For sale are stock parts removed from a 158K Summit White. Everything offered is in used but serviceable condition.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions unless noted otherwise. I accept all payments via PayPal to: [/b][email protected][/b]
If interested please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
Engine Mount Bracket (Rear) $20.00
Alternator Bracket $8.00
Cam Gear $15.00
Crank Pulley Bolt & Washer $8.00 *2 available
Crankshaft Sprocket B $20.00
Flange $3.00
Silent Shaft Sprocket $15.00 each
Water Pump Pulley Set $15.00
Throttlebody Ground Tab $3.00
Spark Plug Wire Guide $3.00 each
Aircan Vacuum Line Mounting Bracket $15.00
EGR Valve *3 Galant/1g Available $15.00
Alternator Relay part no MD113566 $12.00
Alternator Pivot Bolt $8.00
Oil Cap $8.00 each *3 Available
Fuel Pressure Regulator *1g Non-Turbo $15.00
Fuel Filter Banjo Bolt $3.00
Banjo Bolt (Oil Feed on Turbo) $5.00 each
Banjo Bolt (Coolant Feed/Drain on Turbo) $5.00 each
Fuel Purge Control Solenoid $20.00
Fuel Purge Solenoid Valve w/ Wiring $20.00
Fuel Pressure Solenoid Valve Wiring $8.00
EGR Control Solenoid Wiring $12.00
Oil Squirter Check Valve $8.00
Fuse Box Fuse *Complete set for engine bay $5.00
BODY
Headlight Relay part no MB183865 $8.00 each
Lower Radiator Hose Clamps $1.00 each
Washer Reservoir Hardware Set $3.00
Hood Switch (Alarm) *Rubber cracked $3.00
Trim Panel (Passenger Side) $3.00
Fender Bolts *Summit White $3.00
Horn Alarm $15.00
A/C Condenser High Relay $8.00
MAF Intake Hose Clamp $2.00 each
ECU Harness Retainer $3.00
Timer, Defogger Delay part no MB572253 $8.00
Fuel Filter Bracket *2 Available $3.00 each
EGR Line Retainer $1.00 each
Downpipe Mount $3.00
Exhaust Hardware $1.50
Radiator Bracket Bolt Set $5.00 *Used, four bolts
Side Skirt Hardware Set $2.00
Wheel Well Retainer $.50 each
Galant GSX 3rd Brake Light $20.00
Fuel Door Hardware $1.00
Fuel Door Lock Cylinder Retainer $.50
Tailight Cover (Left Side) $10.00
Tail Light Center Section *Passenger side, slight crack $12.00
License Plate Lights $20.00 for pair
Trunk Lid Bracket $15.00 for pair
Trunk Molding $25.00
Trunk Lid Striker $3.00
Trunk Striker Bolts $2.00
INTERIOR
Fuse Panel $20.00
Fuse Puller (Interior Fuse Block) $1.00
Footwell Carpet Clip Set $2.00
Hood Release Assembly $15.00
Defogger Switch $ 15.00
Dome Light *Sunroof model $40.00
Sunroof Control Motor *part no MB549075 $20.00
Sunroof Power Relay part no MB627895 $8.00
Sunroof Adjust Plate $1.00 Each
Radio Antenna Cable $15.00
Buzzer Switch, part no MB802356 $8.00
Ashtray Cover $2.00
HVAC Selector Tab $1.00
HVAC Vent Tab $1.00
Door Card Handle $5.00 each
Door Handle Cover *Rear Driver side sold $3.00 each
Door Light with lens $5.00
Door Sensor $5.00
Control Unit, Door part no MB543647 $15.00
Driver Window Switch Cover $5.00 each
Driver Window Switch Cover $3.00
Window Switch $15.00 each
Door Sill Hardware $2.00
Armrest Stay $15.00
Arm Rest Hardware $1.00
Seat Trim Bolt Cover $1.50 each or $20.00 for full set
Trunk Trim Access $8.00
Tool Bag $8.00 each
P/S Pump Mounting Hardware Set $2.00
Cruise Control Cable mount *Mounted on Passenger Side $2.00
Front Control Arm to Subframe Bolts $10.00 *Per pair
Front Subframe Lower Plate & Stopper $5.00
Gusset Plate Bolt Set $12.00
Front Steering Rack Brackets $20.00
P/S Line Bracket $3.00
Rear Suspension Mount Bolt *1 left $8.00
Driveshaft Hardware Set $3.00
Slave Cylinder Mounting Hardware $1.00
Shifter Bracket Mount Hardware (Lower) $1.00
Shifter Bracket Mount Hardware (Upper) $1.00
Transmission Mount Hardware $2.00
BRAKES
ABS G Sensor (Rear) $20.00
ABS Sensor Mount (Front) $3.00
ABS Ring (front) $20.00
ABS Dust Shield $20.00
Parking Brake Stay $8.00
Brake Fluid Level Sensor Wiring $5.00
Brake Fluid Reservoir $20.00
Rear Brake Caliper Bracket Set *Powder coated gloss black $40.00
ENGINE
Cam Gear $15.00
Flange $3.00
BODY
Horn Alarm $15.00
INTERIOR
Fuse Panel $20.00
Ashtray Cover $2.00
HVAC Vent Tab $1.00
Door Sensor $5.00
Armrest Stay $15.00
Tool Bag $8.00 each
SUSPENSION & STEERING
DRIVETRAIN
BRAKES
