blacksheep
I am swapping all fluids in tranny, t-case and rear end this weekend. I have the fluids from JNZ. I am wondering about the crush washers for fill and drain bolts. I assume I need to replace them. I called local mitsu place and they don't have them handy /ubbthreads/images/graemlins/banghead.gif
EDIT - These are the p/n's and sizes I have, could be incorrect
Oil drain plug washer - MD050317 (14mm)
Manual Transmission drain plug washer - MD000312 (18.2mm)
Manual Transmission fill plug washer - MF660036 (16mm)
Rear diff fill plug washer - MF660036 (16mm)
Rear diff drain plug washer - MB001294 (18.2mm)
Transfer case fill plug washer - MF660036 (16mm)
Transfer case drain plug washer - MN130495 (18.2mm)
Any suggestions where I can get these? NAPA etc ok? Is there a size I have to tell them? Any advice appreciated. Thanks!
