Cigarette Lighter Dead
...fuse is ok under the dash...any ideas if there is something that is common and causes this?
I am sure I will figure it out one day, but would rather try and get it knocked out now if it is easy.
Any thoughts?
Thanks
jepherz
KC, Missouri
they get corroded and stop working from my experience. If you pull that part of the dash off, use a multimeter to check for voltage.
Check the wires on the back. +1 on the useage of the volt meter, with the key on.
Thanks all, I can handle it...it is low on the priority list...just checking it all out before hand.
I solder blobbed across the back black wire which wasn't gripping. All is well!!
Thanks!
4thStroke
Vancouver, WA
If it comes down to it... Ive taken alligator clips and attached one an end to each lead on the battery, then touched/clipped it to the corresponding part on the lighter and got it ignited that way.
You may need to pull over to tackle this one.
Desperate times call for desperate measures. /ubbthreads/images/graemlins/grin.gif
Im serious.
Smitty1457........... /ubbthreads/images/graemlins/rofl.gif +1
Thats great.
You need it for the Nazi's at the emissions station so you don't have to turn off the car and run into start up enrichment issues.
4thStroke
Vancouver, WA
^Oh boy... dont even get me started up on hot start enrichment at DEQ /ubbthreads/images/graemlins/mad.gif
