matt92vr4
Hi everyone, I tore down my engine this weekend and found a spun rod bearing. I also noted damage to the front BS delete bearing. Has anyone seen these get damaged before? It does not have a BS in it and it was new when installed. The engine was running when I pulled it. It wasn't in good shape, but I've pulled many more that sounded a lot worse that didn't have this much carnage inside. What is the main cause from oil starvation? I had a new pump. Everything was new. Hate to put all new stuff back in and have the same problem. Do you think I should replace the entire front case? This one only has 3000 miles on it. Thanks, Matt
