Cam Gears - EVO 4-8 cam gears VS VR4 cam gears
Dialcaliper
Mountain View, CA
The items are the same, but the timing marks on the intake cam will not line up (I believe the Evo is 90 or 180 degrees off, and the gears are off to match). The exhaust cam gear should line up just fine.
However, if you intend to degree the cams in, it won't matter - you can do a rough measurement to get it in the right orientation and then make your own marks with the gear set at zero. Then finish degreeing in the intake cam with the gear.
bazeng
Melbourne, Australia
The dowels on the camshaft sits at 12oclock correct?
I've basically lined mine up so that the dowel points up and marked the cam gear on the sides (3oclock and 9oclock) and lined them up to suit.
This should be sufficient correct?
H05TYL
Wgtn, NZ
the marks on the vr4 cam gears aren't at exactly 3 and 9 o'clock, I think the 3 is more of a 2.58 (get a straight edge and have a look)
brisvr4
brisbane australia
What gears are you using Barry?
bazeng
I bought them from techsport, they are some Aussie brand but look like tomei's. They are designed for a 4-8.
I just lined up the dowel to the stock ones and remarked the cam gear which is 1 tooth off to the left of the original mark. So I just lined up the new zero markings with the stock and new cam gears and marked the side markings. Looks a bit funny when you look it at, but it'll work. I'll punch the new markings in permanantly.
RedTwo
New Zealand
So it has the same number of teeth? No difference but the markings?
Wonder why people make cam gears for Evo 4+ but don't make them for VR4/Evo when all it takes is a change in markings?
brisvr4
brisbane australia
I'm using Skunk gears in mine and they have both dowel holes punched in them.
They suit Evo's and VR4's.
brisvr4
brisbane australia
It does Barry.
Here is a pic of one of mine. The VR4 dowel hole is the one at the top.
Quoting RedTwo:
uhhhhhh.... we have the exact same engine as the 90-93 mitsubishi eclipse, eagle talon, and plymouth laser.
I can tell you that almost every major manufacturer makes cam gears for the 4G63T engine.
Just look up an eclipse and use that.
bazeng
Great, it means I haven't stuffed up =)
what did they set you back?
They look pretty good
brisvr4
brisbane australia
I got them for $135US back when the Aussie dollar was about 95c US /ubbthreads/images/graemlins/smile.gif
They are a LOT more expensive now I think!!
