Buying ECU
When getting my ECU does it matter if it was out of a FWD or AWD. Just as long as it's a 5 SPD and Turbo ECU right?
Terry Posten
Davenport, Iowa USA
All you need is an ECU from a TURBO 1G/GVR4 that is an EPROM board. I would stay away from a 90 TEL turbo ECU because you would have to swap 2 wires around on your harness to make it work correctly.
Auto, FWD, AWD does not matter. The chip that you have made will allow the car to run great as long as you tell the programmer (Keydiver) what you have in your car.
Ok thanx, Got a 94 5 Speed Eprom rebuilt( New Caps) and socketed. number MD304482-E2T60871-
EB21..
Good decision. The 1994's have better caps, so they never leak. But, you MUST change chips before you can use that ECU, as it has emissions stuff in it that can't be turned off.
