Anti theft won't turn off
galantrevolution
las vegas, nv
On my drivers door when I unlock the door,anti theft will turn on ,the headlights flash, but if I unlock the passenger side first then the anti theft does turn off, so what do I need to get on my driver side door to get it fix?
AnotherNewb
Orlando, FL
Jiggle the key...
Seriously I would check the wiring to that door, especially where it passes through the door jamb to the body. Some time spent with a multi meter will tell you whether it is the switch or the wiring.
Fish
Idaho Falls, ID
Do this, I had the same issue along with some power window problems only with the door was open.
I pulled the rubber boot back and found a broken wire and another four or five that were rubbed through and shorting together. After fixing this I haven't had a single problem with the anti theft.
If you can't figure it out, here's a sure way to disable it: alarm delete thread. You can always reconnect the wire later. Quick fix if the anti-theft is killing your battery and keeping you from being able to drive the car.
mitsuturbo
Near Seattle, Washington
Sometimes simply wiggling the wires in the door hinge area will fix this. Of course, only temporarily. In order to fix this right, you have to pull the plug all the way through, and replace entire sections of wire. If you try soldering or splicing in the area where the wire is broken, it will fail in short order. You pretty much have to go from the pin in the plug to somewhere well inside the door with a new piece of wire.
galantrevolution
las vegas, nv
So i pull the door panel and check the connector behind the lock cylinder , clean the connections and it work for like a day , then it happen again, so maybe bad switch?
