Another slave cylinder issue
971of1000
joplin, mo
I am having issues shifting. I replaced the slave and bled it multiple times. I power bled, two man, vacuum bled etc. and it is still not engaging fully. What different slaves will work and maybe work better than what I have?
971of1000
joplin, mo
UPDATE: bleed the clutch with sped blessed. Car shifts fine when not running but only will go into 3rd and 5th hesitately.grinds 2nd,4th, and reverse and won't go into 1st at all. I am running skateboard bearing in the cables. Would this mean the cables are bad? Or is the bearing the issue?
iLLeffeKt vr-4
NYC
Shifter needs to be adjusted or cables are bad. If it doesnt go in certain gears while the engine is off then more than likely the cables are bad. But try adjusting it first to see if anything changes.
rgeier11
Chicago Suburbs, IL
Make sure the roller skate bearings aren't frozen to the shift assembly on the transmission. You need to make sure it is well lubricated. Take the shift cables off the trans and shift if by hand at the transmission to make sure you don't have internal transmission problems.
971of1000
joplin, mo
The problem was that the right cable came apart. The bearings slide on and off but are tight. Shifting is precise.
971of1000
joplin, mo
still a little hard to get in gear. i will be bleeding the clutch a little more soon. Is there another slave cylinder that may offer a little more throw? Mine has the silverish piston in it
Perkul8r
Mandan, ND
I went to rebuild my slave this weekend and when I got it apart it has a red piston in it. Sadly the rebuild kit was wrong. So I just put it back together with a extended slave rod and now my clutch is working fine.
Oh, I have a comp clutch that is equal to the ACT 2600
There are two slaves, to answer your question. One has a ~ 13/16" diameter piston, and the other has a ~ 3/4" piston. The smaller of the two will have the longer throw, assuming that they are being supplied by the same volume of fluid.
I would also check the master cylinder for leaks. Peel back the little rubber boot (under the dash, inside car) and see if it is wet in there.
