ABS light
frank1
anaheim
what are the affects with driving with the abs light on I wonder just because I would like to do a 5 lug conversion and will be driving with the abs light on
is it a big deal ? /ubbthreads/images/graemlins/confused.gif
Hertz
Chicago, IL
The ABS light is probably on because of a system failure. Did you pull the fuse for ABS? That will cause the light to come on. Removing the cluster is rather easy, pull the bulb out. And/or do a full ABS delete... I think if you start pulling the right stuff it will cease to light up.
frank1
anaheim
Ok so if I would to do a five lug convertion can I just drive. With the. Abs light on and won't affect my daily driving ? Or cause major damege ?
iLLeffeKt vr-4
NYC
You can drive it with the light on. The ABS will not function but you can still drive the car without any issues.
