i got beat by a honda on 5 psi it was imbarassing cause everyone knows im fully built wit a 35r tuned for 13 psi i dont know what to do /ubbthreads/images/graemlins/frown.gif
You do know your not even creating wind at 13psi on a 35r correct? If you want to run 13psi put a 14b back on. Also if yor fully built why wouldn't you be running 25+psi?
how about get your car fixed and tuned properly. then go ask this person for another race... double or nothing.
then, hopefully, you wipe off that grin on his face.
@ 13psi on a big turbo you are not gonna accomplish much. A lightweight Honda with higher compression even on only 5lbs can make enough power to run pretty quick.
Get a rope to quench your embarrassment and put an end to the shame!
Ha ha, j/k...who cares; at the end of the day, it's an appliance Honda. But, yeah, you need to get into the efficiency range of that turbo and don't run anybody until then (not that I condone street racing and assuming you mean at the track)
What kind of Honda was it and what were his mods? I beat my friend with a fully gutted/caged 2000 Civic Coupe with a Type R motor/trans with basic bolt ons. I was running a stock block with a 20G and about 11 psi. This was from a 20 mph roll. I had to turn my boost controller all the way down for him /ubbthreads/images/graemlins/devil.gif
Quoting passo:
If you're fully built then you shouldn't be running only 13psi. IB4 "well I'm not really fully built but I have a lot of stuff done."
Basically what happened was...he was making more power with less lag in a lighter car w/ less drivetrain loss. And, he was probably a better driver too as is suggested by the fact that he's using his setup to a much larger fraction of it's potential.
If you want to be faster, you've got to turn up the boost and get that turbo into it's efficiency range. That is assuming that the rest of your setup is designed to keep up with your turbo. Make sure that your engine is happy and that you've got enough fuel and then give it MOAR PSIs!!!
Why would you even tune a 35r for such low boost? What's the point of such a turbo if you're only going to run stock boost levels? I think the lowest I would tune one for is 20psi and then tune for 30+psi with meth/e85/racegas.
I think somebody got in over their head. /ubbthreads/images/graemlins/uhh.gif
