14" afco uca too long?
tektic
ronkonkoma, ny
Was on the alignment rack today and couldn't get it done. Had over q decry of positive camber with my 14" Afco upper control arms maxed out.
I guess I should order some 13" ones?
This hapen to anyone else?
mitsuturbo
Near Seattle, Washington
I'm having trouble understanding what "q decry" means. However, i'm interested to see if anyone else has issues with the afco arms, since that's what i have now, although they're not installed yet.
tektic
ronkonkoma, ny
"a degree" stupid phone spell check...
I'm at about +1.2 degrees on stock springs. Looking to be at -1 . Both rods are all the way in on both sides of the tube.
mitsuturbo
I got that "q decry" was probably something in degrees, but wasn't sure if it was a number or what.
I'll check my tubes when i get home today and see if it would be possible to shorten them a little bit, if you're not sure. They're just sitting in a box right now, so probably easier for me to check mine than you checking yours.
tektic
ronkonkoma, ny
That would be great thanks. I don't under stand this. everywhere I look people say get the 14" I got the set second hand new from 3sx or whatever. The 3kgt site. The bushings are the right size maybe the hemispherical joints are a different size? I don't know what the deal is but the cant get me in spec.
If I cut them will that reduce there strength? That's the whole point of Swedged isn't it? I dont know ... I'm asking.
