Galant VR-4 Forums » Galant VR-4 » Newbies » Where to order a datalogger??
Mr_Wolfy
Galant VR-4 org Post #: 471993 posted 05/01/07 06:43 AM     Remind Me!  Send Private Message   Edit Post
Hi!!
I'm now after a datalogger for my VR-4, where can i order a logger with cable and everything??
Anyone that has ordered from obdlogger.com or digitaltuning.com??
Which program is it that those places sell together with the loggers?? I only know of MMCD
Thanks // Wolfy
| | | IP: (83.166.18.42) | Report this post to a Moderator
Hollowned
Galant VR-4 org Post #: 471994 posted 05/01/07 06:48 AM     Remind Me!  Send Private Message   Edit Post
www.dsmloggers.com
| | | IP: (64.223.82.31) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 472007 posted 05/01/07 07:23 AM     Remind Me!  Send Private Message   Edit Post
Greg's cord is the burliest I've seen too...better than any of the eBay garbage.
-Cy
Posts: 8936 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (198.105.0.129) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 472065 posted 05/01/07 09:31 AM     Remind Me!  Send Private Message   Edit Post
If you have a JDM dual-board ECU the logger will NOT WORK.
Ryan Hertz
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (69.209.93.194) | Report this post to a Moderator
Mr_Wolfy
Galant VR-4 org Post #: 472122 posted 05/01/07 10:35 AM     Remind Me!  Send Private Message   Edit Post
No i have a single board EPROM ECU!!
Edited by Mr_Wolfy (05/01/07 10:36 AM)
nmvr4
Galant VR-4 org Post #: 472499 posted 05/01/07 07:46 PM     Remind Me!  Send Private Message   Edit Post
What is involved in the install? My computer is to slow
| | | IP: (208.54.14.45) | Report this post to a Moderator
TOF
Galant VR-4 org Post #: 473022 posted 05/02/07 05:13 PM     Remind Me!  Send Private Message   Edit Post
Directions for Installing Logging Software
1. Put the labeled Palm Desktop CD into your desktop/laptop computer
2. Install the contents of that CD onto your computer
3. Using the black Hot Sync cable connect the Palm Pilot to your computer
4. Go to the Start Menu, Programs, Palm Desktop, then click on the Palm Desktop Icon
5. Insert the unlabeled Cd into your CD Rom drive
6. Click on the “Install” button on the left hand column of the Palm Desktop Software
7. Click the “Add” button
8. Using the drop down menu select your CD Rom drive
9. Double Click the file name MMCD.prc
10. Close the install window
11. click “ok” to the dialog box that pops up
12. Press the Hot Sync button on the black Hot Sync Cable connecting the Palm to your computer.
13. Allow the hot sync to complete and disconnect the Hot Sync cable
Directions for Hooking the Logging cable up to your Car
1. Locate the Diagnostic Port next to the fuse panel under the drivers side dash
2. Connect the three free wires on the logging cable as shown in the diagram:
3. Connect the black Hot Sync cable to the gray datalogging cable
4. Connect the opposite side of the black Hot Sync cable to your Palm Pilot
Directions for Running the MMCD Logging Software
1. Turn on you Palm and make sure the upper right hand drop down menu says “all”
2. Click on the MMCD logo
3. Click “new”
4. Uncheck “pause”
| | | IP: (72.24.199.233) | Report this post to a Moderator
Scientist
Secretary of the Interior
Galant VR-4 org Post #: 473042 posted 05/02/07 05:40 PM     Remind Me!  Send Private Message   Edit Post
any options for jdm ecus?
1988 VR4....Needs a lot of TLC
Posts: 530 | From: Roseau/Dominica | Member Since: 01/18/07 | IP: (208.158.5.138) | Report this post to a Moderator
speedyvr4
Still looking for the forest!
536/1000
Galant VR-4 org Post #: 473126 posted 05/02/07 08:23 PM     Remind Me!  Send Private Message   Edit Post
I have the ebay garbage . I bought the same reman. palm for 40 bucks at fry's electronics and the cable off ebay w/ the mmcd software. Also bought the serial cable (palm to cable) from ebay.
palm = 40 bucks
ecu cable = 15 bucks
serial to ecu cable = 10 bucks
being a cheap bastaerd with a dsm and a gvr4 = priceless
so for 65 bucks I got everytiiiiing
110 not a bad price though. my 2 psi
Posts: 1245 | From: miami, fl | Member Since: 01/02/06 | IP: (75.18.48.80) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 473326 posted 05/03/07 09:09 AM     Remind Me!  Send Private Message   Edit Post
I don't consider the eBay cable I got from countdepoligonize to be junk. It seems to be well-made, is auto-ON, so it doesn't interfere with the ABS, and he will ship it with either a MALE or FEMALE connector, so it will work with Palm or notebook. For $5 more he shipped it with a null-modem adapter so I can use it with both. Not bad for $25.
| | | IP: (74.246.126.243) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 473339 posted 05/03/07 09:26 AM     Remind Me!  Send Private Message   Edit Post
www.dsmloggers.com FTW.
-Cy
mitsu90
Should've seen it coming.
1544/2000
Galant VR-4 org Post #: 473411 posted 05/03/07 11:17 AM     Remind Me!  Send Private Message   Edit Post
my logger cost me a total of $14.75, and that was just for the palm everything else was free.
here is a link to MMCD V1.8G
1544/2000 Nile Black.
Posts: 706 | From: Illinois | Member Since: 11/16/05 | IP: (74.135.210.131) | Report this post to a Moderator
Mr_Wolfy
Galant VR-4 org Post #: 473449 posted 05/03/07 12:26 PM     Remind Me!  Send Private Message   Edit Post
How many logger programs is there available for the Palm??
It seems like there is many programs, which one is better than the other programs??
// Wolfy
CP
Galant VR-4 org Post #: 473450 posted 05/03/07 12:28 PM     Remind Me!  Send Private Message   Edit Post
You want to upload mmcd v1.8g...linked above.
-Cy
Mr_Wolfy
Galant VR-4 org Post #: 473465 posted 05/03/07 12:48 PM     Remind Me!  Send Private Message   Edit Post
Already done that
Is that a good program to log with?? Or is there better programs than MMCD??
Edited by Mr_Wolfy (05/03/07 12:48 PM)
mitsu90
1544/2000
Galant VR-4 org Post #: 473466 posted 05/03/07 12:50 PM     Remind Me!  Send Private Message   Edit Post
mmcd is a great for logging very user friendly.
CP
Galant VR-4 org Post #: 473488 posted 05/03/07 01:20 PM     Remind Me!  Send Private Message   Edit Post
That's the latest and greatest that isn't a beta version.
-Cy
Mr_Wolfy
Galant VR-4 org Post #: 473518 posted 05/03/07 02:12 PM     Remind Me!  Send Private Message   Edit Post
Ok!!
Which PDA's works with the MMCD program??
Does the other logger programs have the same PDA support system as the MMCD has??
s_firestone
Ctrl-Alt-Boost
918/1000
Galant VR-4 org Post #: 473599 posted 05/03/07 04:54 PM     Remind Me!  Send Private Message   Edit Post
I'm running a Palm M505(color), I hear an M515(Better screen contrast) runs fine.
Stephen Firestone
1992 GVR4 #918 of 1K
Posts: 1610 | From: Park City, UT USA | Member Since: 06/27/02 | IP: (76.107.117.242) | Report this post to a Moderator
Mr_Wolfy
Galant VR-4 org Post #: 480452 posted 05/17/07 01:21 PM     Remind Me!  Send Private Message   Edit Post
Why don't the Palm Zire 22 wont work as a logger?? I mean, i know that this is a USB unit but shouldn't it work when i use the RS232 serial cable?? Or is it the programs like the mmcd, palm 'n' stein and dsm logger and so on that don't work on these units??
I mean, the Zire 22 are some nice units
Some one that knows a answer on this question??
Thanks // Wolfy
speedyvr4
536/1000
Galant VR-4 org Post #: 480789 posted 05/17/07 10:49 PM     Remind Me!  Send Private Message   Edit Post
somebody sticky that link in the how to section ppleeeaze
Posts: 1245 | From: miami, fl | Member Since: 01/02/06 | IP: (75.25.47.38) | Report this post to a Moderator
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.104 seconds in which 0.075 seconds were spent on a total of 14 queries. Turbo powered.
